Group: DynoMotion Message: 9204 From: ricochetproducts Date: 2/17/2014
Subject: Program Status Indicators
Hi Tom,  I have been looking and cannot find an example for program status bits that I can use for my remote console.
I have indicator lights for the following.
M3
M4
M8   /  M9
I also want to indicate PROGRAM RUNNING, and FEED HOLD
Can I monitor M numbers?
Can you please help or point me in the right direction?
Regards,  Steve
Group: DynoMotion Message: 9205 From: Tom Kerekes Date: 2/17/2014
Subject: Re: Program Status Indicators
Hi Steve,
How is your Console connected?  To KFLOP?
For M codes if there are outputs for Spindle On/off Coolant On/off you might just read those directly and  "echo" those to other Outputs?  ie:
SetStateBit(XXX,ReadBit(YYY));
You would probably need a service loop running forever that would test the various conditions and then set your indicators.
// Global Host Status    extern int HostStatus
// As host is requesting Global Status from KFLOP it can also optionally
// specify its status as a 32 bit field.  Bits can indicate its state and
// modes such as whether a a Job is actively running so KFLOP should inhibit
// mpg jogging
#define HOST_JOB_ACTIVE_BIT 1 // bit0 indicates Host Job is Actively running
KMotionCNC sets a "HostStatus" word in KFLOP where bit 0 indicates whether a program is running.  Here from the PC-DSP.h file
// mpg jogging
So something like:
SetStateBit(XXX,HostStatus & HOST_JOB_ACTIVE_BIT);
Feedhold state can be determined from this variable being non-zero (from KMotionDef.h)
extern int CS0_StoppingState;         // emergency stop in progress, 0 = not stopping, 1=stopping coord motion, 2=stopping indep
ie
if (CS0_StoppingState > 0)
   SetBit(FEEDHOLDINDICATORBIT);
   ClearBit(FEEDHOLDINDICATORBIT);
Group: DynoMotion Message: 9206 From: ricochetproducts Date: 2/17/2014
Hi Tom,  My console indicators are connected to Kflop via Konnect I/O
Thanks for you quick reply!
Steve
